Case Mod, Frozen Temps, Window Help?
SirCyber
Ok, so it's three fold in my first real thread here.
FROZEN TEMPS
http://www.frozencpu.com/products/97...l=g49c415s1047
I'm thinking of using this for my computer build. I've heard that it's not a good idea to use these for long periods of time, but I haven't heard why. Any news on this would be appreciated!
CASE MOD
I definitely would not want to run that outside the case, that would be to messy. so I want to mod the top of a Lian-Li case ( http://www.frozencpu.com/products/98...=g1c7s27#blank ) to accommodate the compressor. any advice on that would be helpful, as I have never really used a dremmel or done any metal work.
WINDOW HELP
Of the three, I have the most questions about this. I heard, about 2 years ago, of a window modification utilizing multiple acrylic windows. what they would do is etch each acrylic layer with a different design, and then utilizing different colors of LEDs to light the layers *i.e. layer a using red, layer b using green, layer c using blue* to make the etches from the three layers be part of one image on the case but mult-colored and nearly 3-D.
Thank you for all the advice I *hopefully* get!
NO NO NO..
the Cryo-Z was great for dualcores, and low wattage processors.
HOWEVER..
Once u started getting into quads, and i7's the unit fails horribly.
Meaning u wont be too happy when your in the higher range OC's for a sub ambient unit.
FINALLY! 3 forums later and countless PM's, I have a reply. thank you aigomoria! Now that I got that outta me, are the quads to powerful for the Cryo-Z? Can you tell me where I can find someone who has done this with the Core I7's? I'm still in build phase, next week I should be purchasing the EVGA classified, and probably also several *max of 4* plexiglass sheets or maybe my dremel kit
NO my friend has one.. and he wants to get rid of it.
He however was lucky to receive one for free to do a review.
You will HATE it.
You will HATE the phase controler.
You will HATE Insulating.
You will HATE it when something goes wrong.
In short, dont get it period unless u know what your doing.
Get water instead if you have the budget.
You can get a decient CPU only setup for the price on that cryo-z.
Phase is not something you should try right after air.
Im sure IDC can tell ya he went though hell and back doing so.
