- Sep 12, 2001
- 48,518
- 223
- 106
I have an Inwin Q500N full tower with 3 80mm Sunon high-speed fans now. I am adding two 120mm Deltas in the side panel, blowing onto the motherboard/processor area, and two 92mm Delta blowholes on top. I will probably put all 3 80mms to exhaust, to try and keep up with the 120mm fans.
What I want to check on *before* I cut into this case, is if my fan placement is okay.
Side panel 1 The circles are where the fans will go - one above the other, on the left side of the panel.
Side panel 2 The fans will be on the left side, blowing on the motherboard/processor area.
Top panel 1 You can see the pencil lines where the 92mm fans will go. Sorry its so light..if my desktop system's hard drive didn't die a few minutes ago, I could photoshop it and make it darker..sorry
Top panel 2 That's what's below the top panel. The hard drive sitting there is what I backed up my data with, it's not staying there.
I may add a second power supply just for the fans (until I get a 431 Antec or something..heh). I have a 200w AT power supply which I may install on top of my current power supply. Aside from cutting the back panel to allow the power cord to plug in, can you see any potential problems with a setup like that? The power supply has a rocker switch, so I could turn the fans off from the front panel, which would be convenient (I don't want to make a fanbus just yet, and there's no way I'm going to afford one).
The power supply will fit under the rear 92mm fan, but there isn't a whole lot of room between them. I really want two blowholes on top, though...
Blowhole + 2nd PS
Blowhole + 2nd PS pic 2
Blowhole + 2nd PS
