- Jan 6, 2003
- 337
- 0
- 0
k, tryin to install my mobo in my case, tryin to connect the front panel stuff. i have front mic, speaker, usb, and firewire. now, nothing matches. the case has a 2pin MIC, 3pin EAR (but only has 2 wire, wire in 1pin and 3pin), 2 2pin N.P., 2 1pin GROUND, and 2 1pin +5V. my mobo has seperate USB and front panal audio. for my mobo basicly looks like this
USB PINS;..................................................................FRONT PANAL AUDIO:
.UBS+5V |0 0| USB+5V...............................................MIC2 |0 0| AGND
USB_P5- |0 0| USB_P6-......................................MICPWR |0 0|+VA
USB_P5+|0 0| USB_P6+................................L.ine out_R |0 0| BLINDE_OUT_R
.........GND|0 0|GND.........................................................NC |0 0|
..................|0 0|N.C..............................................Line out_L |0 0| BLINE_OUT_L
K, where goes where? what the hell is BLINDE_OUT? i know R and L are right and left. what the hell is N.P. on the case wire?
next question is i have front panal firewire, but the firewire cord is just a gray cord with a plug in (typical firewire connoctor). i can't hook that up to my mobo, the mobo has pins. how do i solve this? from the case, i have a 7pin cord. with the mobo, i have 6pin to 8pin converters. on the mobo, i have 8pin connectors, on the rear case pci slot, i have 6pin connectors. can i only hook the mobo plug into the rear pci slot adapter? or can i get the frontpanal firewire directly connected to the mobo (8pin to 7pin adapter?)?
brandon
EDIT: bah, i just realized nothing lined up like it was suppose to, let me tweak it.
EDIT: k, go it. the zeros inside the | | are the pins.
brandon
