need red and blue lights in case with window, for a friend.
don't matter what case it is, i'm just going to use anything, what i need help with are suggestions on the simplest and cheapest way to get a blue and red tube to just glow or flash on and off by hitting a switch
i'm putting together a case, and i've seen software activated modules/controllers that work within windows software. if i could avoid software, that would be better.
doesn't need to be sound activated, and prefer it not to be because i've heard of their terrible build quality and volatility issues in workmanship.
basically, red and blue light flashing on a case. window. that's it.
thanks in advance!!!!
