I have a LianLi PC60 Case and an Intel D850EMV2 motherboard. Building my first comp ever. All thats left is hooking up the case LEDs to the motherboard. I've run into a slight problem though. According to my motherboard manual, each LED should cover 2 pins. Some of mine cover 3 and 4 pins like speaker and power led. Also the motherboard manual only mentions about some of the case LEDs. Some don't exist in the manual.
Case LEDs: Power SW, Speaker, Power LED, HD LED, Reset
Motherboard Manual: Power LED, HD LED, Reset, Ground, +5V
How come some of these don't match up? Even of the ones that do, according to the motherboard should only cover 2 pins, but they seem to cover more than 2 pins. What's going on here?
Thanks for any help you can give.
