Case LED not working. Please help, very urgent!
IronMentality
228
Ok, I have a functioning PC with everything working -- except the blue Case LEDs don't light up in the front. There's a wire inside that comes out of inside the front door panel that goes into the case. I removed the FDD 3.5" and HDD storage areas to see where this wire came out.
Near the rear 120mm fan of the case, is a 2 pin connector. I assume I have to plug this in somewhere to make my case LEDs function. What I don't understand is last time I used this case for a build, the LEDs worked automatically, and I never had to do anything like what I am doing now.
I have no idea what to do in this situation, and I really need some help pretty badly. I have built three PCs before, but this is the first time I've ever encountered a problem like this. Am I SOL, or is there some hidden pins I am unaware of or a safe place I can plug this 2 pin connector on my motherboard? I doubt I could plug it into my blank AUX fan port. (it wouldn't even go that far).
Pretty please, dire help is necessary. I'll be actively looking for replies, as I need to get this done as soon as possible. Thank you!
EDIT: Here's what the front of my case should be looking like -- http://www.thermaltake.com/xaserCase/tsunami/sna/sna.htm
Of course I have no blue light :(
spherrod
3,897
www.steveherrod.com
Not too experienced with this kind of case - normally there is a couple of pins on the motherboard for the LED, what is the make and model of the mobo?
IronMentality
228
The Motherboard is an Intel D945GNT.
Believe it or not, buried where I tied a whole bunch of wires together (the Case LED wires like Power Switch, HDD LED, etc.) I found a blank two pin wire. This cord went right into a 4 pin connector that was hooked into my power supply.
Just pushed the two together, fired up the PC, and the LEDs lit up effortlessly. Case closed. I sure do appreciate the help though spherrod. :)
spherrod
3,897
www.steveherrod.com
:) great stuff - time for a celebratory :beer:
