I found the right pins on my atx case button/led module for the power button wire from the atx mobo, but I havent found the right pins to plug in the wire from the hard drive led motherboard pins. The pins on the back of the button unit are 2 pins tall by 8 pins wide. The wire from the mobo is 2 pin wire and fits nicely up and down on two pins and works good. Ive tried all the other pins the same way with the wire for IDE LED but the IDE LED never lights up. Is it possible the wire should go left to right like a couple of the connectors on the chassis set of pins on the motherboard? Also, the system power LED pins on the motherboard are 3 pins, I thought the 2 pin spdif wires I have on hand would do all the connections to the button/led module in my case, but they are all 2 pin wires, and this power light connection (at mobo) is 3 pins, do I need a 3 pin wire to connect to the button/led module in my case. I wish I had the money to just go get a new case with the wires already there and labeled for easy attachment to my mobo. This is my first pc build.
Asus A7V133 mobo
Micron Millenia ATX Full tower case
ATX power supply 300wt from Antec
Athlon Thunderbird 1.2ghz 266fsb cpu
Thanks for any advice.
Asus A7V133 mobo
