CASE LED LIGHTS HELP
nmhsjunk
I have a new case but I want to turn off the led lights! There seems to be no switches and the case has the LED on 24/7. It was good at the begining but its very annoying now. Another problem is that the fans are connected to fans so if I dissconnect individual lights, the fans turn off also. It also has 2 led's in the front. If u have an idea on how to turn it off plz tell me. THIS IS THE NEWEGG LINK OF MY CASE plz look at it plz. THANKS LOT
Originally posted by: Baked
Cut the wires or smash the LEDs w/ a 5 lb. sledge hammer.
Bwahahaha! Good one! :laugh:
Yeah, at least smash the LEDs in the front of the case. Those are the ones that bug me. All the rest, I can live with...
Originally posted by: thecoolnessrune
Why did you buy a case like this when its whole point is to light up?? 😕
For the same reason people buy an expensive car, but then never drive it?
I don't know either though.
Remove the front panel (bezel) and cut the wires to the indivicual LEDs and replace the fans with non-LED fans.
.bh.
