octopus41092
I'm going to be using a Swiftech MCR320 and a Swiftech MCP655. What case could fit these in? I know of one at the moment, the Coolermaster HAF 932. Preferably for $150 or less and full tower, what other ones are there?
Originally posted by: octopus41092
So, going by that 2 MCR220's would be better than 1 MCR320 for sure though right? Because I was thinking if I were to get an Antec Twelve Hundred, I could put one in the back and one in the front and it would work out fine. I'm thinking of the D5 Vario so I think the pump is plenty strong enough too. What's your thoughts on doing this instead of getting the CM HAF 932 w/ one MCR320?
2 mcr220 ~ MCR420 (if it existed)
So 2 mcr220's would be better then 1 mcr320.
exactly what are you watercooling tho?
cpu only? or both cpu and gpu?
