Case for Horizontal Micro ATX Mobo and Noctua NH-D14
Showtime
Hi,
Looking for ideas on a new case that will support a Micro ATX mobo with a Noctua NH-D14 cooler and mounts horizontally.
I just picked up a micro ATX mobo from ASUS after my Gigabyte mobo crapped out and had issues with RMA. So one problem led to this different issue. The cooler is massive, but was ok since I didn't move my p180 tower. Now, I'd like to be able to move it around safely and use something lighter/smaller than my old case. Noise is a slight concern, but the cooler works well as long as there's some air flow so lots of vents or a couple well placed fans should be plenty.
Fenix Prodigy the original non M version. Currently at top of list since I know it can be modded and looks fine.
Thermaltake Urban S1
Antec ISK600
I like the way these look, but will have to check to see what will fit.
Other choices:
Aerocool DS-Cube Black
Silverstone SG05B-USB3.0
Xigmatek Aquila
Xigmatke Gigas
Basic Parts:
ASUS z87 Gryphon Micro ATX mobo
4770k with NH-D14 Noctua Cooler
Asus GeForce GTX 760 2GB DirectCU II Video Card
Corsair HX620
Thx!
The Silverstone TJ 08 might be what you are looking for even though its a vertical mount. It has a heatsink and fan holder for large heat sinks to prevent sagging due to weight. I have the nh-d14 as well as the tj08 and this heat sink holder works perfectly.
