Case filters and a Company that works
Micrornd
1,343
221
I've been using Demcifilters for some time now.
I find them to offer very little restriction to airflow.
They are easy to clean and they can be had in many "off the shelf" sizes for many different cases and fans, as well as being available in any custom size.
They keep the dust out of my builds.
They also have a simple timer app available for free download that acts as a countdown timer that reminds you when to clean the filters.
You set the time interval, and yes, it is a simple thing, but I don't see any other filter makers even offering anything like that.
Demcifilters are available in shops around the world or direct from them.
They are in Capetown, South Africa.
As to the type of company they are, I ordered direct from them on my latest order as I needed an odd, but still standard size, just not stocked in the US shops.
My order was shipped the same day I placed it, and took 9 days to get to me in FL (I chose the cheapest shipping)
When it arrived, it was totally wrong, I got someone else's order.
I emailed them and let them know, even though it was 8pm their time.
They responded the following morning (their time, 6 hour time difference here with DST) with an apology and assured me my order would ship out that day and I should keep the other product they sent.
The best part of this was that I had received an email from FedEx 20min before receiving Demcifilter's email apology.
FedEx indicate that Demcifilter was sending me a package via "FedEx International Priority" (2nd day before noon).
You really can't ask for much better than that!
And, no, I don't work for or represent Demcifilters or even get a discount.
But when I find something that works, I think others should know ;)
inachu
2,387
I use BOUNCE sheets when they are used up taken after use from the dryer.
readymix
357
Demci is good. I like them, I use them because I think they are the best solution. But, they do restrict air flow, by about 50% before they start to collect debris. that is still sufficient for my box though.
Ayah
2,512
I use swiftler sheets personally. extremely high restriction but also extremely good at catching debris.
aigomorla
21,054
3,545
i built a sub frame around my mountain mods so i could attach a HVAC filter on the top compartment where all my radiators are.
The bottom main portion i use demci filters.
I have been using them since introduction on Xtremesystems.
By far HVAC filters are superior... i wish case manufactors would make a case which could use them. Until then my modding skills will have to do.
