In the last few days I have transfered my equipment to a PC60 Lian Li Aluminum case, as this case looks so goo I really dont want to drill any holes in it for additional cooling. I am wondering about upgrading the Factory fans to aftermarket. The case comes with a 80mm rear and two 80mm front fans from the factory.
If I decide to change out these fans, should I just be looking at CFM, or is their other considerations? Also does a higher CFM automatically mean that it will be noisier? WHat would be your recommendations for a superior 80mm case fan?
Thanks a bunch...
NeDDoG
Thanks a bunch...
NeDDoG
