- Apr 18, 2005
- 73
- 0
- 0
Originally posted by: AndyBogard
Where can you even buy Nexus fans, or Yate Loon fans for that matter? Alot of people here on the forums keep mentioning those two brands, but I have never found an online retailer that carries either of those brands.
Originally posted by: OCLeo
You can get your Nexus fans (which comes with both 3-pin and 4-pin) from www.us.ncix.com . If you really are concerned with quietness then go for Nexus but if your ok with a little baring noise and more air than Nexus than go with Panaflo's. I've also read that Panaflo's made in China are not consistant in quality, a bit noisy compared to the one's made in japan.
Check out the recommendation for fans at www.silentpcreview.com.
Good Luck
Originally posted by: rod
You said Papst and Panaflo's are good. What about SilenX? Their supposed to be really quiet (<14dBA), and they seem to have good reviews.
