Case Fans??
avijay
84
I'm looking for some good quiet case fans, both 90mm and 120mm. Anyone got any ideas?
Maxil223
195
go to Newegg.com, and read all the user reviews. I do understand that you want some AnAndTech member opinions, but since no one has posted, I suggest that.
Mrvile
14,066
A lot of people like Panaflo, but I find them kinda loud. Good fans though if you can handle some noise.
A nice quiet fan would be the Vantec Stealth 120mm. Good air flow, great sound level, only problem is that it costs at least 15 bucks apiece.
jterrell
559
It depends on your tolerance for noise and if you will be overclocking.
I use generic Speeze case fans from newegg.com and they do the job fine for cheap.
Case fans can be cheap since they are easily replaced and cheaply.
Check out www.xoxide.com if you want fancy/pretty/l33t ones.
loic2003
3,844
If you're looking for some pretty fans, you can't go wrong with the aluminium titan fans. the actual moving parts are plastic coated in shiny stuff but they look great.
I have a couple of 120mm's in my machine,, running at a nice slow speed (about 1400 RPM), mounted on rubber mount jobbies, and the only sound you can here is the massive amounts of air flowing over the components....
Here's a link: http://www.titan-cd.com/english/alufan.asp
