- Mar 6, 2001
- 59
- 0
- 0
I have an ABIT KG7 mobo and will be adding (2) 80mm or 120mm case fans to the side panel.
Is it better to get case fans with the (3) pin connector and attach the power leads from the case fans to the mobo connectors or get (2) case fans with (4) pin connectors and attach them to the power supply connector? Also, I am adding amother HDD and will need (1) 4-pin power supply connector to attach the new HDD to.
Thanks.
Thanks.
