Hi ,
On my mothers PC is has :-
1 x 120 Input Fan @ the Front Bottom of case.
1 x 120 Output Fan @ the Front Bottom of case.
1 x 80mm Input Fan @ Centre of the Side of Case .
Within 2 days the inside of the PC Case is covered in about 3mm or more of dust ??? . :frown:
I read somewhere before that you can set your fans up to create either Negative or Positive air pressure inside the PC case pressure .
So there's air blowing outwards from all the little holes around the case , so the dust cant get is because of the air being pushed out .
Does anyone know which type of fans and setup ie [120mm / 80mm / 92mm / 200mm would create this so the inside can stay clean .
I have tried ladies stockings over the fans to block the dust but they get clogged up and the dust still gets in .
I have Fan filters for my 120mm & 80mm Fans but the just get clogged up with dust within 2/3 days and the amount of air the fan is bringing in /out reduces to about ¼ or ½ of its supposed to .
The PC is in the Kitchen and theres a lot of Dog Hair and dust around so i understand that some dust will come in , buy at the moment it just Ridiculous . :roll:
Any help advice very much appreciated .
Thank You
[ I E ] When i repair other peoples PC's like relatives the bought there Systems from Dell / Tine / Gateway etc . Inside there PC is always immaculately Clean ?
Thank You
