Case Fans in to Mobo or PSU?
jskagg
52
Hey guys, I am building my first computer and everything is going fairly well so far. I have a question though, I have an ASUS P5k-e Wifi/ap and a Corsair 520hx power supply and a Coolermaster 690 case. I am installing many fans to keep the case cool (around 5 to 6 total). Is it a good idea to plug them all in to the motherboard since there are enough slots? Or should I plug some in the PSU? Complete specs and fan types are below.
Here are my specs:
Q6600 with Coolermaster Hyper TX cooler
Asus P5k-e Wifi/ap
Samsung DVD Burner
Seagate 250gb HD
evga 8800gt
2 yate loon 140mm
1 yate loon 120mm
1 scythe 120mm
2 Coolermaster 120 fans
Blain
Use splitters and connect as many as you can to the PS.
Some will need to be connected to the MB for temp/speed control.
jskagg
52
So plugging them in to the motherboard is a bad idea? Why is this? (Just trying to figure everything out, the motherboard has 5 fan headers)
OdiN
Banned
Mar 1, 2000
16,430
Plugging into the motherboard is fine. You just need to make sure that the fans don't draw more power than your MB headers supply, or you'll burn out all of the fan headers on the board, or at worst damage the board.
0roo0roo
64,795
84
yup depends if you think the mb fan control is usable.
i just plug my fans into a fan controller so i can fiddle with speed manually.
JackMDS
29,546
422
Plugging the Fans to the Motherboard is a convenient to computer manufactures.
In reality, it is a Bad idea and should be avoided if possible.
Why?
More current through the board more Heat the components, and might decrease and destabilize the voltage to some components too.
Fans create electrical noise, there is capacitors to squelch the noise, but Not everything disappear, and there is No reason to let Noisy signal into the Mobo to begin with.
jskagg
52
Wow, Thanks for the answer JackMDS. That is exactly what I was looking for. I ended up plugging in all put the HS fan and one intake fan in to the PSU. I am installing windows right now!
