OK,
I've been having some issues with overheating in a Lian-Li PC60A+ case used in a system I built for a friend.
(similar to this case, but with an axial fan blowing out the back instead of a fan blowing out the side in the bottom left)
MB: Asus A8N32 SLI Deluxe (heatpipe cooling) (2nd one - had similar problem with first, thought it was a bad board...)
CPU: AMD 3800+ X2
CPU cooler: ZALMAN CNPS7000B-ALCU 92mm 2 Ball Cooling Fan
Vid: 7800GT (single)
Mem: 2x1Gb Corsair XMS
case temps - high 40's
CPU, - supposedly just high 50's according to AsusProbe
locale - Indiana
Now, if i close the case, it'll run for a little while then - whammo, freezeups, reboots, general ickiness.
If I take the side of the case off and get a *tabletop fan* and blow the thing right at the motherboard, it will run for hours and rarely freeze up....
I had at first been attempting to use some Nexus 120 and 80mm fans (front and back, respectively.
That didn't work, so then I switched back to the stock Adda fans and still no go.
This use of a tabletop fan is obviously NOT a long term solution, so now, I'm considering getting some high CFM (and thus, high dB) Panaflo's such as these:
120mm
U1A:
Air Flow 114.7 CFM
Noise Level 45.5 dBA
H1BX
Airflow ? 103.8cfm
Noise ? 41.5dba
Rotation Speed - 2500 RPM
M1A
Airflow ? 86.5cfm
Noise ? 35.5dba
Rotation Speed - 2100 RPM
80mm
H1B
SPEED: 2950 RPM
AIR FLOW: 39.6 CFM
NOISE: 32.0 dBA
The goal was *silent* computing, hence the use of the A8N32 and it's passive cooling design in conjunction with the quiet LianLi case.
Clearly, that's just not happening. I guess my concern is that using these high db fans (45dB!) will be too loud for him. The case sits on the floor, so it's not right next to his ear..
Am I missing something obvious here? This should have been a totally adequate cooling system, in my mind...and I hate the fact that I've got to consider getting new fans...but.......what "ceiling" would you recommend? 35dB? 40dB? 45dB? I just can't decide how much cfm I can get away with without making him feel like he's in a fighter jet hanger.....
CPU: AMD 3800+ X2
locale - Indiana
120mm
U1A:
Air Flow 114.7 CFM
H1BX
Airflow ? 103.8cfm
Noise ? 41.5dba
M1A
Airflow ? 86.5cfm
Noise ? 35.5dba
80mm
H1B
SPEED: 2950 RPM
AIR FLOW: 39.6 CFM
NOISE: 32.0 dBA
