Case fan wires
aigomorla
21,137
3,675
Assumption your looking at this:
black.. (-)
Red.. (+)
White... (RPM Sense)
Blue (PWM Sense)
You can ignore the blue and White wire.. attach a 12V DC Adapter to the black and red wire.
If you get the + and - mixed up, dont freak out... the fan will just spin backwards lol..
Change to proper layout and it should spin in the proper direction.
CAUTION... Some Dell Fans are very high speed fans... be VERY CAREFUL of your fingers as it can cut you good..
philosofool
283
19
That's exactly what I'm looking at. I will be using 5V DC, but it should do the trick. Thanks for the injury tip.
