- Sep 24, 2007
- 7,655
- 2,935
- 136
Building a new PC, first time doing something other than a budget computer. I'm using a Corsair Carbide SPEC-01 ATX mid-tower case (http://www.newegg.com/Product/Product.aspx?Item=N82E16811139041). There are five fan slots: 2 in the front, 2 on top and 1 rear. Case comes with a 120mm fan in front. I've bought three more 120mm fans and can get a fourth. One will be installed in front blowing in over the HD rack. I'm only going to be using a SSD mounted in a 3.5" bay so incoming airflow should be fairly unimpeded.
My question is should I configure the two top and one rear fan for exhaust or should any do airflow in? I do have a NZXT Sentry Mix 2 fan controller as well.
