I am getting either the Thermaltake Tsunami or the Soprano case and I had a few questions.
1 - Do you think that the stock fans that come with the case will be good enough? (2 - 120mm 1400rpm fans, 1 intake front, 1 exhaust back) and (1 - 90mm 1800rpm fan on the side window)
2 - If I were to get a Panaflo 2400rpm fan, would it be more effective as intake from the front or exhaust in the back?
3 - I was going to get the XP-120 heatsink, what fan do you recommend for it? Panaflo? Tornado? Noise doesn't bother me really, I want great airflow.
Thanks in advance!
Joe
Thanks in advance!
Joe
