Case fan - pull or push?
Brazos
11
I'm building a pc for a friend. Of course the power supply has an exhaust fan. There is room in the front to add a 2nd fan. Should that be pulling in air (to create a positve pressure)? Or another exhaust fan (pulling out air)?
My gut feeling says to pull air in but thought I'd check with the experts.
Thx
Siamskunk
1,281
That's right, 1 direction. Front pulling in and Back pushing out is the most common method.
Which mean you can have back fans pulling in and front fans pushing, might sounds obvious but it also works.
All in all, you have to some experiment 'cus all cases are not made equal.
jhites
1,854
Like everyone said, front lower fan pulling cool air in and top back pushing air out. Check the P/S fan to be sure it is not a smart fan (only turns on at certain temps). You want to balance the amount of air in and out to get good flow.
cipher00
1,295
Ditto. Most rear/out fans are "high" or should be (sometimes space requirements make ppl do odd things to case positioning) since heat rises. Front "low" fans help get the circulation going...
5mudge
59
Now the question is: What percentage of PCs are incorrectly built with respect to fans?
ericd
355
When I was in college way back in 99 :) I saw one guys computer that was a FULL tower and he obviously had gotten in his head "more fans the better" I think this thing had like 9 or 10 80mm Sunon High outputs.....all blowing into the case. You could hear the fans straining from accross the room. He couldn't figure out why his processor kept overheating. The side of the case practically blew accross the room when you took it off while the fans were running.....not really but you know what I mean. It was almost too hard to make hime feel like that much of a moron by telling him....almost. Still don't know what case that was, no case I have seen before or since has ever had that many fan mounts....and he didn't have to cut any of them.
Eric
