Hey!
I currently have 5 fans in my case (1 120mm front, 1 120mm back, 1 120mm on the side, 1 80 on top and one 80 on the lowest part of the case)
Thing is... my motherboard has only two 3 pin connectors (2 SYSFAN connectors, one CPUFAN and one NBFAN) and one of my 80mm fan is plugged in it... and my Zalman fanmate will probably be taking the second spot..
So right now... all the case fans that came with the case are plugged in a molex connector and using the adapters I can plug all the fans together... but it leaves me with ONE HELL OF A HUGE WIRE!! with all the molex connected.
My question is.. does anyone know what I can do to resolve my problem? because I don't want to have so much fans plugged in the molex connectors
thank you
thank you
