Case Fan Orientation...
crazylegs
779
OK... so this is going to sound really dumb... if i add a case fan(s) to the back of my case (near PSU/ CPU/ GPU) should it:
a) Blow air in
b) Blow air out
Then, if i have 2 fans hould they:
a) Both Blow air in
b) Both Blow air out
c) 1 Blowing in 1 blowing out
Thanks All !!
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
#1 -- b. Becasue these components generate heat, and you want to get the heat out of your case.
#2 -- Depends where you put the fans. In most cases (not pun intended), you want air to come in from the front, through the case, and exit the back and / or top...
Do I get a cookie for answer? Or atleast a "Have you helped a n00b today?" t-shirt?
GalvanizedYankee
6,986
Google internal air flow. Several decent sites will be on the first page.
http://www.heatsink-guide.com/ > case cooling. The articles are not tech heavy at this
site. Bookmark it and do a little reading/homework.
We all have to do our homework ;)
I want a ballcap, no t-shirt for me.
...Galvanized
