I'm a complete newb when it comes to installing case fans.
I was considering getting this case for my next build:
http://www.newegg.com/app/ViewProductDesc.asp?description=11-170-012&depa=0
However, I also want to install another fan on the side window or possibly at the top. Seeing as the side window is clear, do I have to drill a hole in it? Do case fans attach in another method? If I attach it on the side, how do I position the fan? (I assume position it so the air goes outward, since there is no side grill, so the rear case fan can move the air out)
I did a search for it online, and there were a bunch of guides for the rear and front fan, nothing about a side panel one.
