Case Fan for HP Pavilion p6510f
I've got a 1.5 year old HP Pavilion p6510f and the case fan has failed. I've tried a Google search for "HP Pavilion p6510f Case Fan" but can't figure out how to find a replacement fan. Does anyone have any ideas on how I can find the correct fan to replace the fan that is no longer working? It's a simple fix if I can get the right part. I don't care if it's an HP part. Somehow the BIOS knows that the case fan has failed so I don't know if there's some sort of sensor on my current fan.
remove the fan that isn't spinning and take it to your local computer parts store to match it up.
Looks to me like a 92mm fan with 3 wires, so any fan that same size, with 3 wires should work.
