Mantrid-Drone
My 'newish' build desktop (i3 Gigabyte H87- HD3 8GB RAM) has worked near enough flawlessly for the first 9 months of its life. However earlier this week rather than the gentle hum of the case and CPU fans which, once the storage HDDs spin down and SSD is all that is being used, I heard something different.
It wasn't loud but it sounded like a fan motor had stuck or something was physically blocking the fan. I opened up the PC case and discovered that the two Akasa PWM 140mm Viper fans (one intake the other exhaust) were not spinning. They're powered from one fan header (Syst. 2) using an Akasa two way splitter cable (4 pin/3 pin).
No physical cause could be found so I checked the cable connections, shut the PC down and rebooted. The fans both spun up as normal and did so for the rest of the session. However the next day the same thing happened again, at some point those two fans stopped spinning.
The fans are 'guaranteed' for 50,000hrs and have had less than 500hrs use.
All the other fans (2 x 120mm intake, 2 x 120 CPU cooler and 1 x 120mm exhaust) operating from the other three 4 pin MB fan headers are running fine.
The PC should have plenty of power. The PSU (XFX 450W Bronze) can't be the culprit as it is very much over spec for the system even if it were being used at full whack. This problem appears to happen intermittently usually when the PC is doing little more than idling ie. it doesn't occur specifically when the system is under more stress.
If it were a power on that specific fan header issue you surely expect it to stop the fans completely but, as I said, from the sound of it when this happens the fans are trying to spin so they're certainly getting some power.
What might be the cause of this because the symptom don't make sense to me?
I don't understand enough about how PWM works to know if this is possible but I'm wondering if it is something to do with the PWM control of the 'master' 140mm fan of the pair. If that is cutting out both fans are stopped even though they're receiving power.
Does that make sense and if so would it be the 'master' 140mm fan that is causing this, a problem with the header itself or the MB PWM control of the header?
Advice appreciated.
Advice appreciated.
