case fan connection on motherboard
srini0603
88
my intel dh57jg motherboard has 4 pin for the chasis fan, but the chasis fan has only 3 pins on it.
can I put that on any 3 pins on the motherboard, either leaving the first or last one, or is there an specific way I need to connect?
kiriakos
101
www.ittsb.eu
I bet that the connector on the motherboard, has an plastic pin, that the 3 Pin plug ,
gets in it , by only one way ...
If this plastic is broken , then take a picture and show it to us , so to help more.
srini0603
88
no the plastic is not broken, the fan has a 3 pin connector only but the motherboard has 4 pins...i will try to load some pics this evening.
BoomerD
65,907
14,309
http://resources.mini-box.com/online/MBD-I-DH57JG/MBD-I-DH57JG-manual.pdf
page 23
"Fan Headers
The function/operation of the fans is as follows:
• The fans are on when the board is in the ACPI S0 or S1 state.
• The fans are off when the computer is in the ACPI S3, S4, or S5 state.
• Each fan header is wired to a tachometer input.
• All fan headers support closed-loop fan control that can adjust the fan speed or
switch the fan on or off as needed.
• All fan headers have a +12 V DC connection (up to 12 V DC when using 3-wire
chassis fans).
• All fan headers are controlled by Pulse Width Modulation.
• The chassis fan header supports linear fan control on 3-wire fans.
The Desktop Board has a 4-pin processor fan header and a 4-pin chassis fan header
compatible with 4-wire and 3-wire chassis fans."
pic on pg. 49
srini0603
88
mv2devnull
1,526
160
Not quite correct. Three of the wires/pins deliver 12V, ground, and speed reading. Your fan needs those. The fourth pin is for PWM control. There should be only one possibility to connect, as shown by kiriakos.
srini0603
88
OK, my bad the 3 pin will go in one way only, the plastic is at the back as per the pic from Kiriakos.
thanks for your help guys.
