Well,............I'll add another vote for the Fong Kai 320 or the 603 which is smaller ......
I don't think anything about this case looks cheap, .... if you are going to cover your drives to prevent dust, dirt, hair, etc. from entering your case then the sliding door works great .....
If you want added security .......... then it is cheap and flimsy as there is no way to secure it like the SX-1030, but it does flip up and store completely out of the way ........
The F-K cases are an inch or two deeper than most others, so you gain some additional clearance from the rear of your drives to the ps or inside edge of mb. The side covers are not as easy to remove as the Antec SX-Series cases, but they fit very snug and do not rattle, keeping the airflow inside the case flowing in the proper designed direction.
Bottom line is pick the case you like the looks/price of the best, you can't go wrong w/any of the above forum members' suggestions .......................!
