Buy a Digital Doc 5. It can control up to 8(7 bcs one is located on the unit) fans and monitors temperature with 8 sensor probes. It is the best thermal sensor on the market IMHO. Follow the link and you can buy one for $65. At least it does say that on the front page of the website. Good Luck! 😀
Alternatively you can download Motherboard Monitor for free from here. It's not as sophisticated as a Digital Doc, but it'll read the temperature sensors off your board and CPU.
