BlueBomber
Hello all!
On Friday I built my new system and while I'm amazed at how quiet it is I've also noticed that CPU temps while gaming seem pretty high (to me anyway).
I'm using the following equipment:
Case: Fractal Design R4
CLC: Corsair H90
CPU: i5 4670K
The way I currently have things set up is 2x 140mm Fractal Design Silent Series R2 fans (that came w/ the case) at the front of the case, and with a single 140mm Noctua NF-P14 FLX attached to the H90's radiator. I'm not sure if I have the fans, # of fans, or direction of the airflow configured optimally, so I'd like some advice.
For reference, the Noctua runs at 1200RPM with an airflow of 64.96 CFM while the Fractals run at ~1000RPM with 66 CFM of airflow. Corsair recommends that the H90's fan blow cool air in, but I currently have the Noctua sucking air out because the two fans in front are (currently) intakes. I could buy another Noctua and create a push-pull config. Right now I think I have more air coming in w/ the Fractals than the Noctua is expelling. I don't know if that's a problem, since I don't know much about the effects of pressure in cooling a case.
Over the weekend I noticed while gaming that the CPU cores could hit the low 70s (Celsius) on occasion, which seems high to me. This is with everything currently at stock. I should say that the ambient temperature in the room was rather hot due to SoCal weather (90F/32C) so I'm sure that contributes, but if anyone has any advice on how to modify my current setup to increase cooling, or if you think the temps I'm seeing are normal, I'd appreciate any feedback.
Thanks!
CLC: Corsair H90
CPU: i5 4670K
Thanks!
