Case Cooling Opinion Needed
0utlaw
10
hey guys, ive decided that i want extra cooling for my case and my case supports 3 extra 80mm fans and im thinking of getting the enermax whisper. what i would like to know is, the best way to orient the three fans so they keep the cpu cool. ive attached a drawing of my case (excuse my l337 photoshop skills :p) . ive named the three fans A,B and C. im thinking of orienting fans B & C so that they push the air out of the case, while A pushes air into the case. my only concern is that fans A & B will kinda cancel out each other and therefore wont really be effective. ideas anybody?
Also, my PSU's rated at 300 watt and i'd like to add a cold cathode and lights,etc to my case. how can i calculate/know whether my current PSU can handle the extra load?
any help would be greatly appreciated. Thanks!
4 year old's rendition of my case
Jan 31, 2002
40,819
Can't tell you much on the CCFL, but here's my take on things.
I'm assuming that's a tower case, so the vertical's a little more stretched, correct?
If so, that's just fine (low front intake, high rear exhaust, side intake) - what I'd recommend though is finding some plastic tubing and ducting that side fan onto your CPU.
- M4H
0utlaw
10
what exactly do you mean by 'ducting the side fan onto the cpu?'. and where can i get this plastic tubing? thanks a lot again.
amdskip
22,530
13
Plastic PVC piping available at your local hardware store. Some people use dryer venting too, possibilities are endless. A cardboard tube would work too. It will just suck air in from the side directly into the processor.
