Case/Cooling Advice, Opinions...
DasSmoof
Okay, to put it simply. I´m growing tired of my case.
http://smoof.madebymonkeys.net/Comp/comp3.jpg
http://smoof.madebymonkeys.net/Comp/comp2.jpg
It´s a decent enough case, I´m just pretty tired of it´s looks. I´ve matured a bit in the time since I bought it and I want something a little less.... tacky...
I have an old (two actually) Pentium 3 sitting in my room, from HP. The case is fairly nice, it´s very conservative and I was thinking about perhaps using some model paint I have and spraying it black.
http://smoof.madebymonkeys.net/Comp/comp6.jpg
http://smoof.madebymonkeys.net/Comp/comp5.jpg
However, I discovered a problem
http://smoof.madebymonkeys.net/Comp/comp4.jpg
There´s not a whole lot of room inside. There isn´t anywhere to mount a fan, besides inside on the front of the case at the bottom. But the holes there are very small and look to really choke airflow. Other than that, the inside of the case is kind of cramped, but simple, which I like. But it might be hard to cram a CD-RW/DVD-RW/Two HDD´s (eventually) and a floppy.
As compaired with my current PC
http://smoof.madebymonkeys.net/Comp/comp1.jpg
The Current PC has threeish fans in it, all which blow pretty well. My main concern with putting my new PC in the other case is the fact that it may not get enough cooling. With a dual core processor and the 6800GS, this seems that it COULD be a problem. People say that the processor I have runs cool, so should I be concerned? I MIGHT down the road overclock either a little bit, in which case, cooling would be a bigger problem.
But really, opinions/advice? I really want to use the P3 case, but I´m just worried I wont be able to cool enough.
Dont use that P3 case. Itll kill your stuff from heat in less than a day... if ur sick of that case CoolerMaster and Antec offer great cases that arent tacky. Those cases that are linked are highly recommended.
Too expensive really. I already have a 450W PSU from Antec, so I'm looking cheap cases that are $20 or less, if I decide to get a new one.
I probably wont, since I can't really afford it 😛
Uh, there are some coolermaster centurion 5 on sale for $55 at newegg as well. the ones without the power supply are less.
sometimes you can get cheap Antec cases directly from their web site when they`re getting rid of inventory or whatever...
Take your $20. Mod the left side cover for a large window. Sand and paint the top panel and both side panels to a light color(light colors hide defects better) of you liking.
Mod a 120mm fan into the new window just below and to the front of the CPU.
Fan w/grill=$6
Paint and fine sandpaper=$12
Small piece of plexi=$4
So for around $20 it can be done.
...Galvanized
