Case choosing Help
Weeeman
2,114
Hello all.
Here's what I'm looking for.
Black Or Silver [Prefer Black]
Window
Room!
Decent airflow...
Thats a pitiful list, but thats what I'm looking for.
Everything I begin to like doesn't have a window...[6070 Lian Li, Sonata, Coolermaster,Beantech Igloo]
I've been stuck with my default dell case for about 4 years too long and think it'd be nice to change it up a bit.
How are Super Lanboys?
Any Other Suggestions
Peace
gordanfreeman
205
it wouldnt be too hard to just install a window on most cases, and i know that antec sells pre-modded side panels to fit nearly (if not every) all their cases.
Cerb
17,484
33
86
Sounds like you want Antec or Chieftec (Antec sells modded Chieftec cases, as well).
Weeeman
2,114
Sounds good.
Any suggestions on where to search for the pre modded side panels for say....a sonata? :p
Havent really shopped anywhere but newegg...
Peace
Thanks!
gordanfreeman
205
the only thing i know about the pre-window-modded side panels is what i saw on antec.com they have a cpl different styles of windowed side panels that you can buy direct from antec (yea not the best price i assume) but at least then you could get the model # and search elsewhere. otherwise i have seen window modding kits available at a few different online stores for pretty cheap.
nageov3t
42,808
83
CoolerMaster ATCS. black aluminum with a removeable motherboard tray and a side window.
doesn't look riced out, but some LED fans and tubes will fix that nicely :p
Mermaidman
7,987
93
I'm partial to Antec cases--High quality, yet affordable and easy to work with. Their drive bays are ingenious!
