Case audio question
T0bias
152
Hey, I got a Antec P182 case and I connected the HD-AUDIO labelled connector to the motherboard, but I don't get any signs of audio from the case? Shouldn't it beep when booting, or how can I test if it works? :)
And in case I should've heard from it, what do you suggest I do?
Cutthroat
1,104
The P182 does not have a case speaker. The HD-AUDIO connector is for the front panel audio jacks, and should be connected to your sound card.
Zepper
18,998
I like having the case speaker - those startup beep-boops are comforting. Found a place selling system speakers for cheap - maybe best byte or something like that. Some mobos even lack the speaker header now and some BIOSes don't generate the beep codes any more either.
.bh.
