Case and size issues
ellisz
266
Hello,
I am looking to build my first system and was already to order an Enlight 7237 300 watt case and AMD XP, etc when I decided to measure the tower opening in my computer desk. The opening is only 19.5" deep and the enlight case says it is 18.9: deep. I figure with the power cord coming out the back and the rest of the hook ups, this will not work.
Can anyone recommend a good cheap case $47-60 range with 300w or better PS that will fit in an 19.5" deep opening? I will have 2 hard drives, floppy, 2 cd roms and an EPOX or Shuttle 266A mother board. I planned on adding a secon fan to the Enlight so a case that supports 2 fans would be nice.
Thanks
CStroman
1,568
I don't recommend keeping your computer in your desk. Athlons need airflow, and if your computer is in a hole, it's going to get hot.
NesuD
I agree with CStroman. Closed in areas with little or no ventilation are a recipe for overheating issues. If you can remove the rear panel and keep the front open so that air circulates freely then it shouldn't be a big issue but if not then I would choose a different location for it.
MoFunk
4,058
I agree with NesuD. Cut out the back if you can and take off the door to eliminate heat issues. It will also solve your depth issue.
Jen
24,206
14
definitly need air flow for AMD's i seen enough suffer from heatstroke
Jen
