Case and PSU
Novercalis
453
Okay, usually im a generic PSU users, I dont care dishing out PSU a year.
however, I recieved a Antec PSU and to my surprised still running (8 months) so since im rebuilding everything again, this PSU is going:
now my question is, what are the tops PSU (450+) names and prices?
now, im looking for a Case, still unsure I want full tower or mid tower.
however, I want somethign that is COOL efficient.
the one I have currently is a "Super Power" Case with the side panel open.
I clean it every first week of the month. usually I dont have to, I have one of those air purifiers near by and lots of blacklights, so they tend to attract more dusts than my comp.
However, I want a case that stays closed, looks DECENT, but not in fear of added heat, moisture.. etc..
Budget on Case along $75.
but do please post other CASE that is higher than 75 bucks and I will consider it.
im not looking for no alienware OMFG leet designs nor a GLASS cause I dont do the neon stuff on my comp.
Im the only one who gets to see it anyways.
Elcs
6,278
For case alone, the Antec SLK3000B almost fits your description.
It has 1 120x25mm fan fitted as standard at the back with space to fit a 120x25mm in the front via the fan holder. I took out the fan holder and screwed in a 120x38mm fan at the front.
It has a side air duct. For testing purposes, I actually removed the duct and was able to fit an 80mm fan there perfectly although Id need longer screws to fit the fan and duct. I run with the duct on, fitting a fan there would be an option open.
It has 4 x 5.25" bays.
It has 2 x 3.5" bays.
The HDD cage situated at the bottom of the case, behind the front intake fan can take 5 HDD's so suits that criteria.
Front panel only accepts 2 USB ports. No audio.
Antec SLK3000-B - $52.00
Novercalis
453
ty, but the more I look at the warrior, the more happy im getting.
Also with 3 fans... and air duct side panel (which reading your post, im sure I can add an addtional fan)... it just might be the winner overall.
Granted im only going to have 2HDD but I want room and I dont like to stick them close to each other.
