Carrying case for 19'+ LCD monitor?
deanx0r
Preferably something that will fit a Hyundai L90D+
Couldn't find anything that would let anything bigger than 18' fit in.
Look for a Halliburton aluminum camera case or something similar. When you see the price, you may just opt to build one out of plywood and cover it with the skin of a Nauga. 🙂
Also, you might modify a small suitcase with foam blocks.
Do you need a "case" (ie, to ship it in), or just some way to carry it? I know GearGrip has an LCD harness, but it wouldn't protect it enough to, say, put it on a plane as checked luggage. If you need to transport/ship it, your best bet is probably the box it came in.
Thats funny, my 19" came in a specially designed case that has a handle right on the top! Fits my panel PERFECTLY! Yours didnt come with one or what?
[edit] Wait a freaking minute, you have a 19' panel?!? Holy sheet! :Q 😎 😕 [/edit]
[/edit]
The L90D+ comes in a box that, tho it has a handle on top, has you lay it down on its side before opening. So you need to tape it shut before carrying it by its handle.
Also the base is a pain to remove (tho it is possible), and it won't fix in the box with the base on.
