Carpenters and would be handymen, need your input...
Homerboy
30,890
5,001
GC started up on the home addition today, and in talking to my wife he said "2 months work, would be another 2 weeks if he was doing the trim work"
I plan on doing the trim work myself to save some $$ and just because I like to do such things myself. But doesn't 2 weeks seem like a long-ass time? It would be ~6 windows, baseboards, 5 doorways and not much else. (bedroom and bathroom). Granted it's one guy that is doing the work (not a team) so the time frame would be a tad longer. But 2 weeks?
What did I get myself into? I fear I may have over extended myself/abilities here.
lozina
11,711
8
do you have a good miter saw and a nailgun? I think it would take me less than a week for that much trim work (assuming your standard trim - nothing fancy) and I'm factoring in paint work/caulking and I'm no pro. prime the pieces in batch before you nail them up (line up multiple pieces right up next to eachother so you can use a paint roller to paint a bunch at once, rotate the pieces and repeat to do other sides - will save some time doing it this way.
fitzov
2,477
Just let the guy do the work. If you don't and you screw it up you're going to be sorry.
Armitage
Banned
Feb 23, 2001
8,086
Yea, two weeks seems pretty long for that small a job. I'm guessing about 2 days to cut & pre-finish the pieces - less if you paint instead of stain/poly. Then another day to actually put it up and another day to putty, finish, etc.
Homerboy
30,890
5,001
can I borrow $2k?
I have a decent miter, no nail gun though. Figure Ill just rent one of the day or so... or just go old school on it.
Certainly will be painting before I put up.
I dunno, this is coming from my wife too, so I'm sure something got lost in translation.
DainBramaged
23,454
41
I asked my grandfather who has been a carpenter for 52 years. He said that it would take him about two days.
Armitage
Banned
Feb 23, 2001
8,086
can I borrow $2k?
I'd just buy a finish nailer if you can't borrow one and you have a compressor. They aren't that much relative to the $2K you'd pay the contractor. Don't go "old school". Hanging trim is *much* easier with a finish nailer, particularly if you're working alone. And you'll probably end up with hammer dings otherwise.
Homerboy
30,890
5,001
no compressor... could borrow one I guess.
don't they make electirc nail guns? or is that a waste of time?
Armitage
Banned
Feb 23, 2001
8,086
I've seen electric brad nailers, not sure about finish nailers.
But this is a great opportunity! "Honey, if I spend $500 on tools, I can save us $2000!" :D
nutxo
6,824
503
I do quite a bit of handyman work. I ALWAYS give a longer timeframe.
#1 To give me time in case things dotn go just right.
#2 Some people feel ripped off when they pay you 400 dollars for a days work.
Electric Amish
23,578
It could take awhile. It depends on what he's doing.
First off, I don't know if the finish nailers will auto-set a nail or not. If so, that will save a lot of time. Otherwise you'll have to hand-set each nail.
Then you have to spackle and sand each nail hole and each joint. I assume he's doing that.
Also, is that 2 weeks @ 8hr/day or what?
Homerboy
30,890
5,001
can I borrow $2k?
You mean you didn't think your addition would cost as much as it's going to?
know I know how much its going to cost... and put aside an extra 10%
but if I can save $2k why shouldn't I?
Amish: Yeah normal 8hrs day $440/day
Hell I don't care if it takes me 6 months to do it. If I save $2k I save $2k. of course the little lady wants into her new bedroom ASAP though :p
Izzo
714
I seem to recall Paslode making a really nice cordless finishing nailer. I used their heavy duty cordless framing nail gun and it sucked donkey balls. But their small, finishing nail gun worked wonders and made trimming a lot easier. It fired easily everytime and had a good adjustment for amount of drive in the nail. I rarely had to use a punch to set the head of the nail into the wood. You should be able to rent one of these. They are a lot more convenient than worrying about air compressor and hoses.
DO NOT old school it. It will likely look like ass when you are finished. '
2 weeks sounds like a lot for trimming out a job like this for an experienced carpenter.
edit: Paslode Cordless
Homerboy
30,890
5,001
Cool very good to know.
I have some friends who are handier than me lined up to lend a hand too, so I feel we can knock it out.
ITJunkie
2,512
www.techange.com
can I borrow $2k?
Definitely rent the nail gun. Nothing is a bigger "p1ss-me-off" then when I make great miter cuts that fit like a glove and then dent the trim with my hammer. The money for renting the right tools is worth its weight in gold when the completed job looks really nice!
Homerboy
30,890
5,001
yeah I dunno why I really made that "Old School" comment. I planned on renting/borrowing a nail gun for doing it (likley borrowing so it can get done at my leisure). I've put up moldings before with a hammer and realized quickly that there was a better way.
