card upgrade/help understanding pci 1.0 and 2.0
Croikee26
Hey everyone, I bought an HP a month ago with the ASUS M2N78-LA motherboard. It only has onbaord graphics so I need to change that. Only problem is I haven't upgraded a video card in probably four years. Last time I did I bought an ATI Radeon 9800.
Now I see there is pci, pci express and then 1.0 and 2.0 versions of pci expressx16. My motherboard documentation says it supports PCI expressx16 but nothing about 1.0 or 2.0.
Can I put a 2.0 in and it will work? How do I know if it is 2.0 compliant? What is a good direct x 10 graphics card for under $200 that would be a great step up from onboard graphics? Thank you!
Oh, how would this new card stack up against a good olt Radeon 9800 pro? :)
Croikee26
Thank you, that helps on one question but the bigger one is how do I find out if my motherboard is pciexpress 1.0 or 2.0? All it says is PCI Express x16?
ViRGE
Elite Member, Moderator Emeritus
167
It's based on the GeForce 8200 chipset, so PCIe 2.0.
ASK THE COMMUNITY
