Originally posted by: Zenmervolt
Originally posted by: LTC8K6
The battery is almost certainly dead. It takes far more power to crank the engine than to run the radio and a few lights. You need to get it jump started and then get the battery and charging system tested.
This.
The starter can draw well over 200 amps when cranking the engine over during a cold start. The lights will draw, at most 25 amps or thereabouts. Lots of people think that if the lights come on it means the battery is OK, but that's just never been true.
ZV
i tried to jump it yesterday when the problem first occured and still nothing. i really think the battery is fine, any other test for the battery besides a volt meter?
It doesn't even jump? Maybe a bad starter relay/solenoid or starter motor? Can you borrow someone else's good battery to test?
not sure i can find a compatible battery just for testing but i could remove the battery and take it to Auto Zone to test if i can find a ride. i had a dying battery on this car a few years ago and it would at least try to turn over/crank which it is not currently doing. i am also thinking starter or solenoid after doing some internet research/troubleshooting.
The click you are hearing is the starter solenoid engaging. If you are hearing the "click", the solenoid is 100% fine. When starters fail, they typically stop completely, they don't get weak first. 99% chance that the problem you are having is either the battery or a bad connection. First step should be to disconnect the battery and clean both the battery posts and the cable clamps. Clean everything until it shines. If that does not at least allow a jump start, clean the cables on the starter end and make sure they are attached solidly.
A volt meter test of a battery tells you very little. You need a proper load tester which can apply a large amp draw and measure how well the batter holds up under load.
ZV
