Originally posted by: BoomerD
Originally posted by: Scourge
Originally posted by: iamaelephant
Take it to a mechanic, you clearly do not have the knowledge or skills to fix the car yourself. Save yourself a lot of trouble and pay someone to fix it.
... Yeah, he doesn't want to rebuild the engine in his driveway, but there isn't anything wrong with looking it over yourself thoroughly before paying for someone else to do it for you.
That presumes that the OP has enough knowlegdge or experience to know what he's even looking at or for...
Let's back-track...does the car start with a jump? You've given several different symptoms. IF the car turns over but doesn't start, that eliminates the battery and starter. (presuming that it turns over enough to actually start the car) That leaves fuel and spark as the next things to check. You say the fuel pump is doing it's job. How do you know? just pull a line and see fuel squirting? MAY not be getting enough to actually run the engine. Bad fuel pump or plugged filter could be the cause of that.
GOOD fuel pressure? then maybe not a good spark. Could be distributor, coil, computer, bad grounds, many different things.
How long ago were you in the accident? Often, an accident will kill a battery. Something about knocking the sediment loose in the battery, which causes problems with the plates inside. I've had it happen twice...minor accident...otherwise good battery craps out within a couple of weeks...There could also be any number of things wrong that weren't caught by the body shop, and if it's been very long after the accident, you may not be able to get it covered by your insurance, BUT, if it looks like it was caused by the accident, talk to your insurance agent.
