Car won't start unless jumped. How to tell if it's the battery or alternator?
Ausm
14
Put a meter on the Altenator to see if it has any output can also be checked by your guages in the vehicle unless you have idiot lights..
Ausm
robphelan
4,084
17
the old method of testing the alternator was to disconnect the neg terminal of the battery while the care is running. If it dies, the alt is the problem.
daveymark
10,573
anyone have an idea if will autozone test it for free? I know they do the diagnostic code checker for free
Titan
1,819
if your alternator is dead, your battery won't charge and your car will prolly die in short order. If it runs for hours after jumping, it's prolly the battery.
I had the alternator go in my old volvo at school. I had to have a friend jump me 3 times to get me to the garage, at night. Boy that was fun. I remember being suprised at how quickly the car died, especially with lights on.
Aimster
16,129
If your car needs a jump then it is your battery
If it was your alternater your car would die in the middle of driving.
Peace
daveymark
10,573
I drove 50 miles after I jumped it. It didn't die, I arrived at my destination. Then this morning it wouldn't start again. Does that mean it's probably the battery?
nakedfrog
63,170
19,506
Yep. 50 miles should have put a bit of a charge into it, so it's probably not holding it any more.
Rumpltzer
4,815
33
Yes, AutoZone will do a load test on the battery and let you know if it's dead. They do it for free. It takes just a few minutes.
They'll also test your alternator for free if you want to take it out. Same deal with the starter.
Rumpltzer
4,815
33
Originally posted by: Heisenberg
Put a DMM on the battery while it's running and see what the voltage is.
To be a little more clear... you have a 12V battery in your car. If you disconnect the battery and measure the voltage, it might read something like 11.5V.
If you turn on the engine, the alternator will charge the battery and you'll read something higher... maybe 14V. If the alternator is dead, you won't read "something higher".
mrphones
1,431
Battery.....Or depeding on what type of vehicle, it could be something in between that's not charging it. I would start with the battery first...
Nov 5, 2001
18,366
Not necessarily true. My Honda had a bad alternator, and it would drain the battery , and I would have to jump it.
OutHouse
36,410
616
yip, i have used this method a few times and has always worked and was correct.
Aug 16, 2001
22,505
4
That must be before stuff like Fuel Injection, ECU and other electronics.
The car will die no matter what if you do that.
homercles337
6,340
Exaclty what i was going to say. Just make sure the car hasnt been runnign for a while. Some batteries are just weak, but will take some charge. So, just jump it, then disconnect the battery immediately.
[edit] meant battery ... [/edit]
Captante
30,354
10,880
Alternators don't always fail completely right away, often they stop charging gradually, so the only way to be sure is to test the charging output, however if your battery is more the 3-4 years old it may be dead too... be really careful if you go to Sears or somplace like that though because they'll rip you right off and have you replacing the battery & the alternator wether you need it or not.. best bet is to test yourself or remove the alternator and take it to Autozone as has been suggested.
DaShen
10,710
Take out the battery and take it to AutoZone.
If not battery,
Take out the alternator and take it to AutoZone.
Scarpozzi
26,392
1,780
What year is the car? Have you ever changed your battery? Usually batteries have 5 year warranties on them. You can expect a battery to last at least that long....some will last 3-4 years....it's a mixed bag.
AZ will check your battery. The alternator can't charge a bad battery. :p
If the alternator goes bad, it will sometimes draw current from the battery even when the car is off... (bad diode can make the alternator (generator) turn into a motor) So start with the battery and don't listen to any mechanics trying to talk you into replacing the alternator yet.....
Phoenix86
14,644
10
Peace
Unless a bad alternator cause the battery to die.
edit: You need to have the alternator tested, not the battery. You know the battery's dead, it's a matter of why. The fact it isn't charging doesn't mean jack. It could mean the alternator isn't charging, or the battery isn't holding a charge.
edit2: Chances are if the alternator is bad, the battery needs to be replaced, but not always.
sao123
12,656
206
Take a drive...
Advanced auto will test your battery, starter, ignition, and alternator for free...
