- Sep 25, 2001
- 29,391
- 2,738
- 126
2005 Mazda3, 100k miles
The car worked fine going to work. At lunch, it wouldn't start. I mean, completely dead without even a click noise.
I notice all the gauges going nuts. The needle is moving from one end to the other. I removed the key, same thing happens and the needle in the gauges keep moving
WTF?! thought nothing could happen w/o the key in the ignition?
A coworker jump started the car and it worked fine the rest of the day. I had a load test done on the battery after work and it came up normal.
So, is my car possessed or what?
Update:
Went to Advance Auto and they ran the charging system test.
Battery: Good
Measured: 705CCA, rated for 640 CCA
Starter: Low cranking Amps
voltage 11.3V, amps 11.6A
Starter Amp draw is low with OK starter voltage
Charging system output test: Normal
Drain test: 1.2A -> Suspect
WTF drains 1.2A?
Update:
Battery: Good
WTF drains 1.2A?
