Car won't start cold...help
Status
Not open for further replies.
gar598
1,915
It seems recently my '97 Volvo 960 in the mornings (or when it hasn't been used for a few hours) is difficult to start. On the first crank it doesn't appear the engine is catching or firing fully. The second crank it catches after a few seconds, though not as cleanly as when the car has been run for a short period or later in the day. As far as I can tell, the car runs just fine once it's started.
I took it to one shop and they couldn't diagnose the problem (he suggested I get a new car). The car has around 126k miles; the spark plugs/coil wire were done 23k miles ago.
Any ideas? Fuel pump issue?
tasmanian
3,811
Your battery might not be strong enough. Or park your car in a heated garage. They also have battery or engine heaters.
Edit : See cold cranking amps. See me.
gar598
1,915
oops sorry...I should have posted to the garage.
I had the battery tested at Autozone and it came back fine. The battery is six months old.
CrackRabbit
16,642
62
Fuel pressure regulator perhaps? It sounds like the pressure is bleeding off when the car is off.
Status
