I got a 96 blazer now, and everything worked on it, or at least I thought it did... i didn't check the air conditioning (ugh I kick myself right now)... and hey, guess what! It doesn't work.
When you turn the air on, the compressor never kicks in (the clutch never turns it on)...
I'm wondering if there's more than one fuse. There's a fuse for "A/C Comp", which isn't broken, and I tried a different one, and that didn't work either.
The dealer will fix it, as they told me it worked great... (they will fix it or else I'll turn blue in the face. The truck I traded in had been recharged and converted from R-112 to 134A... so they will damn well make sure mine works)
What I'm wondering is, do you think if it makes no attempt to turn on, that the compressor is shot? Or is there more than one fuse for it...?
Thanks..
end rant
Thanks..
end rant
