Lithium381
Just wondering, when i shift, my RPM difference is 1k between 1-2 2-3 3-4.........but it's only 500rpm between 4-5 why is that and is that normal? wouldn't i get much higher speed potential if there was the same 1k difference?
Originally posted by: LAUST
i'm driving an 88 4runner
1st 3.928, 2nd 2.333, 3rd 1.451, 4th 1.00, 5th 0.851.
RPM @ MPH can vary also with tire size and axel ratio though, What I posted should be exactly what you have
I run 2200RPM @ 70MPH 285/70/R16 tires 4.10 axel and 4L60-E 1st: 3.059 2nd: 1.625 3rd: 1.000 OD: 0.696
And they still don't hook!!! 😉Originally posted by: mAdD INDIAN
285 WIDTH TIRES! :Q
I like your OD of 0.6...an 0.5 would be nice.
What would prevent a tranny from having a 0.2 OD or something...? Engine power isn't really needed during cruising anyway...
That is where my zuk is at 65ish.Originally posted by: thomsbrain
i wish my car had a taller final drive. ~3400 RPM at 80 MPH is a little buzzy.
Boy, I wonder why 😛Originally posted by: LAUST
well, you know how that goes 😉Originally posted by: Evadman
Their is a fine limit between fuel consumption at crusing. You do not want the gearing so low as to cause lugging, but you want it as low as possable for good MPG. a .2 OD would never work unless you are doing about 200 or so or have extremely high diff gears. (7+)
I bet a Diablo has a final gear in the range of high 3's low 4's though.
285 WIDTH TIRES! :Q
285 WIDTH TIRES! :Q
But HP is what is used to keep the car going. Torque is used to get going.
