Originally posted by: LoKe
They're not to keep the air in. ~_~
Not even a little? IOW, maybe you'd only have to reinflate every 40 days instead of every 20? Or are they just to protect the integrity of the valve (keep dirt out)?
You pump up your tires every 20 days?
Here's an experiment for you: get a pair of needle-nose pliers (Which, based the fact that you don't know how a schraeder valve works, you probably don't own) and unscrew the actual valve stem from the tire. then put the cap on, and see how long it holds air.
Originally posted by: FoBoT
you are joking
i hope you are joking
I have several pairs of needle nosed pliers AAMOF.
*waits for a thread with pictures of a shrader valve embedded in someone's forehead*
