- Oct 11, 2000
- 56,336
- 11
- 0
Car is a 1994 Camry with 252K+ miles 4-cylinder automatic transmission. When I'm driving, and the car changes from 1st to 2nd gear and with my foot on the accelerator, the engine sputters and the car loses power and then slowly catches up. It also does this when going from 2nd to 3rd. But its not there (or at least noticeable) when going from 3rd to 4th gear. No check engine light warning either. This problem occurred all of sudden and not gradually, i.e., it was working fine the day before.
After problem occurred, drove the car home and parked it in the driveway and turned off car. When restarting the car, the engine seemed to idle rougher than usual. Moved the car to the street and the engine seemed like it was going to die. However, after letting it sit for a month, the car starts up fine but the sputtering is still there.
Changed the engine and transmission oil a few weeks prior to problem appearing. Everything looked normal during oil changes. Checked the current oil levels and are within normal operating levels. Passed smog a few weeks before as well.
My brother who is more mechanically inclined than I am thinks its a blown head gasket. When looking at the coolant in the reservoir, it looks dirty with a brown color but it could be from the brown build up on the inside of the reservoir. I poured the reservoir content into a clear 2 liter bottle and the liquid is definitely brown. Opening the radiator cap reveals neon green (i.e., normal color) coolant. How do I check for foaming or milky color if coolant and oil is mixing? Do I open the engine oil cap while the car is running?
Other things I'm thinking it could possibly be:
Clogged fuel filter - haven't changed this in 7-8 years. I'm thinking as press down on the accelerator, its pushing more fuel through the fuel filter to the fuel injectors. Just a guesstimate.
Clogged fuel injector - never changed. No fuel is being injected into one of the cylinders and its running on 3 cylinders. But this should cause the engine to run rough all the time and not just when going from gear to gear...
Spark plug/spark plug wire - Changed last circa 2005/2006. Fuel is being injected into the cylinder but the spark plug or spark plug wire is inhibiting a spark from igniting the fuel. This should also cause the engine to run rough all the time and not just when going from gear to gear.
Timing belt jumped a tooth? This should also cause the engine to run rough all the time and not just when going from gear to gear.
Transmission - FUBAR'ed? Switching between gears works normally and no audible grinding noise is heard. It only occurs right after the gear switches that the engine seems to sputter.
*shrug*
*shrug*
