Car Sub Woofer Question
LandRover
The current sub in my vehicle is a dual voice. I assume this has something to do with having two amps.
I have a replacement sub of the same size, but it's only a single voice (one set of connections).
My question is, can I use the single voice sub and still get pretty decent sound?
dual voice coils just means the speaker has two voice coils you only need to use one of em. to answer your question you can get great sound out of a single voice coil sub.
You'll have to excuse my car audio ignorance, but how would I wire it up?
Would I connect all 4 wires to the one side of the new sub, or just two of them?
The amps and sub are the original equipment in a 12 year old vehicle. It's a Pioneer system.
The other sub I have that I was thinking might work, it came out of a home stereo sub box.
On the bottom, it reads...
Hymnario
IMP: 2, NOM: 20W
(Probably a generic POS, but I don't care 😉)
The current sub has 4 wires total connected to it. 2 wires connecting to each opposite side.
if you have a single voice coil, and one speaker there is only one way to hook it up.... If you have a speaker running less than 4 ohms(unlikely)you have something to think about, but if your amps designed for 4ohms and you connect an 8 ohm it'll be fine, just lack some thump😛
Here's what it says on the bottom of the amps...
Max Power: 30W x 2
Load Imp: 4-8
Input Level: 3V-30V
I know they're not powerful amps compared to todays systems, but I'm more than happy with the sound.
You can wire it up depending on the preferred impedance of the amp. You only need 1 amp to drive the speaker.
